S.Trim and WOT tables
Scuderia
Post by Scuderia »
Hello I'm trying to understand WOT tables. What would happen to the S.Trim if the WOT tables were set to above 12.5 across the board? For example if they were set to 13.34 across the board, would the S.Trim target 14.7 or 13.34?
I dataloged a 3rd gear pull on the factory tune, and noticed it was trimming fuel from 2-4k RPM, despite being at WOT. It was targeting 13-ish, not 14.7 though.
Thanks.
Re: S.Trim and WOT tables
Post your datalog and calibration.
Please do not set the WOT compensation tables above 12.5:1. The ECU behavior can be unpredictable.
DatLife84
Post by DatLife84 »
Are you guys talking about the WOT compensation tables for the low cam or high cam?
both
