High Cam Lambda/AFR Readings
MugenRR
Post by MugenRR »
hi guys,
Some help please!
I have Kpro 3 set-up in my CL9 Honda Accord however I cannot seem to pick up any lambda/AFR readings on high cam during datalogging.
Readings are fine on low cam.
I see the AFR readings while logging, however when I load the log to review, no figures are there.
(I have the latest version of KManager 4.08)
Any thoughts?
Also if anyone can share cam angle maps for a K24 turbo, would be great.
Thanks in advance!
Regards,
Des
(South Africa)
Re: High Cam Lambda/AFR Readings
The K-Pro is not designed to work in an Accord. This may have something to do with the problems you are experiencing. I believe you said you were using a dual adapter harness which we do not support.
MugenRR
Post by MugenRR »
It's a single adapter harness.
It was working fine until I downloaded the new Kmanager version.
