Supercharger
typer86
Re: fuel level gauge
Post by typer86 »
Hi,
I have the same issue with the supercharger. But I do not use the MAP calc. I use the AFM.
The supercharger push air into the engine with 0.5 bar. So the air sensor Register a higher airflow.
After refuel the fuel calc says: You can ride 1200km. But in the real you can drive 500km.
If I switch to the current fuel consumtion in normal drive the ECU tells: 3,5 Liter/100km
That's unreal. Real is 7-8 Liters/100km
The result is if the tank is empty:
If the half of the fuel Level is reached it Drops very quick to empty and the car start crying for a refuel.
I can not believe that it cannot be corrected!
Can I use the the option "Fuel trim" - overall fuel trim? Any sample what is the result if this will be adjusted?
What parameters can be set?
Thanks for help.
I'm not sure why you're using the AFM for a supercharger. The ECU uses injector duration, not airflow, for the calibration. What injectors are you using?
You need to ensure the injector dead times are correct and set the injector flow for fuel economy parameter.
typer86
Post by typer86 »
Hi,
The injectors are from "RC Fuel Injection".
The question is easy to answer why I useing the AFM cal:
The misc features are only enabled in AFM cals not in race maps of the FN2:
> REV-LED
> Check Oil level from the engine
I tested the racemap too and funnily enough the fuel calc is exacly the same. => The ECU displays a total wrong very low fuel calculation.
For the injector flow for fuel economy calc I used the following template:
Source: (End of the page)
http://www.rceng.com/technical.aspx
For setting up the injector dead times I have no technical specs in the package to setting up the opening time (or dead time) of my RC 750cc injecotrs.
Hondata as specialist, did you have any speccs for me which correct data I must enter?
Edit: Will fix the gauge problem if I use your settings from your RC750cc Template: Civic-Si-Race-8-RC750.fpcal ?
Thanks for help!
Regards
I did not mean the race calibration, but the VE (speed/density) tables on the regular calibration.
Your dead times are a little low. I use 1150 us @ 12V and 750 us @ 16V. Be aware that changing this will change the fuel, especially at low injector openings.
Then change the 'injector flow for fuel economy' number. A higher number will give a higher fuel consumption number, so increase it until your dash is correct.
R-12914
Post by R-12914 »
@typer86:
Any news about this?
2008 Honda Civic TypeR FN2
ECU: 37820-RSP-E02
Flashpro: FP-SI-INT-21153
Software: 3.6.1.0
Firmware: 185
typer86
Post by typer86 »
Yes I have some news:
I got a list from RC Engineering for the SH4-750 fuel injecotrs.
Fuel Pressure (psi)
The voltage starts @ 9.0 and ends by 16.0 V:
I configured the following:
10V: 1207
12V: 952
16V: 658
In the list I can not find any entries for 6 and 8 Volts.... 9V is the lowest value.
I will try your settings I keep u up to date
R-12914
Post by R-12914 »
Do you mean this one?:
You can also change the Voltage in Flashpro Manager!
BTW: Ich bin Deutscher, ich denke du auch! ;)
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
typer86
Post by typer86 »
Yes I have the same list received.
Ps: Ja wir kennen uns schon :-) kommen beide aus Bayern ^^
typer86
Post by typer86 »
Update:
I tested now the following settings without any better results. The fuel gauge displays always 3 L/100 km in normal driving. Normally it must displays min 6 L/100 km.
Current configuration:
Note:
After edit the opening timings, now if the K20 engine is cold, in low rpm the engine is jerking a little bit in first minutes of driving.
I don't know what I can do as next. I am happy, for any ideas to fix it.
Regards
Do not use a race calibration and expect the fuel gauge to read correctly. You should use an AFM calibration and just enable MAP based tuning inside that calibration.
typer86
Post by typer86 »
Spunkster wrote:Do not use a race calibration and expect the fuel gauge to read correctly. You should use an AFM calibration and just enable MAP based tuning inside that calibration.
Hi Spunkster,
Yes my cal is a AFM calibration. I will tomorrow post my map of my car. I hope you will find the final switch that the fuel gauge works correct.
I am very happy if you help me to find the solution.
Ps: I think I am not alone of this problem many owners of a supercharged fn2 have the same issue. But nobody tried to find a solution.
Regards
typer86
Post by typer86 »
Hondata, please be reminded that we are waiting for a understandable supercharged FN2 cal with lager injecotrs from RC (750cc).
Edit:
I found in your manual the following setting and the same values are set in stock engine without supercharger/turbo:
Throttle Flow
In some situations the ECU will need to know the air flow past the throttle body for a certain throttle opening.
throttle-flow
This table only needs to be altered for larger than stock throttle bodies.
If I double the flow (l/min) from default to this what is the result?
The supercharger will increase the air consumtion (flow). Why only this value must be increased if a lager throttle body is mounted?
Thats confusing!
Maybe if this setting will be adjusted the fuel calc and the current fuel L/100km will be corrected?
Any example value settings for Supercharger / Turbo are welcome.
Thanks for answering.
Regards,
typer86
Post by typer86 »
For calculating the corrected air flow I found the following interessting site:
http://www.gnttype.org/techarea/turbo/turboflow.html
In my car is:
> Pulley: 110mm
In the screenshot you will see the technical air flow / pressure ration schematic of our Rotrex compressor - C30-94 which are most used in FN2's.
The full PDF doc you can download here: http://www.rotrex.com/media/7df7470f-60 ... 0Range_pdf
How I must calculate the correct Throttle flow vs opening time?
Supercharger
Is it blowing or sucking through the throttle body? What throttle body are you using?
R-12914
Post by R-12914 »
Hondata wrote:Is it blowing or sucking through the throttle body? What throttle body are you using?
The Supercharger is after the throttle body (without a blowoff valve!)
We have the stock throttle body from the FN2!
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
