05 RSX RH Reflash hesitation (slight bog)between 4-5k at partial throttle
daje00
Post by daje00 »
When cruising on the highway between 4k and 5k which is the vtec window for this flash, if you're at partial throttle, it bogs, stumbles or hesitates for a while but if you give it full throttle it pulls right away. It's almost like it has a mild misfire for a few seconds then it clears up.I noticed this with the regular reflash too between 5 and 6k. Is this normal, quite a few other users have been complaining about this too on CRSX. It happens in any gear actually at slight throttle right between 4 and 5k.
Re: 05 RSX RH Reflash hesitation (slight bog)between 4-5k at partial throttle
What exactly is your setup?
daje00
Post by daje00 »
My setup is Invidia RH, stock exhaust with hi flow resonator, Injen CAI, RH reflash.
daje00
Post by daje00 »
Bump!!!
I'm not aware of any others having this problem the reflash. It could be a problem with your TPS sensor or could be the combination of parts setting of some kind of resonance, Without datalogs it is really impossible to speculate on what it is.
daje00
Post by daje00 »
Ok. How can I datalog it if I don't have kpro?
Exactly which is why it is nearly impossible to help with an issue like this that is not happening to anyone else with this reflash.
