AP1 Basemap clarification
Toda party
Post by Toda party »
In regards to the AP1 basemap included with Kpro..
Is the basemap built buy Hondata, or Is it a "clone" of the factory ECU values?
Basically trying to work on some idle and part throttle issues and wondering how much to "trust" the values in that basemap (I know each car is different, etc etc)
Thanks.
Re: AP1 Basemap clarification
It is a calibration created by Hondata using an AP1 If you have problems, then follow the posting guidelines and give more information.
Toda party
Sorry bout not following the guideline. Friend of mine was having issues as mentioned, I wasn't sure if it was a mechanical issue or the Kpro...turns out it was a bad injector...kept running lean despite adding 5, then 10, then 15% more fuel from the basemap. I was trying to rule things out at the time of posting.
Justinthecoastie
Post by Justinthecoastie »
With the AP1 basemap, you will end up adding 10-20% overall fuel to the calibration. Only after you are tuned will overall fuel value be reduced or returned to 0%
