PLX EGT not reading corrently
jdelcorte
Post by jdelcorte »
Hello, i hooked up the PLX EGT analog out to the analog 1 wire on the S300 board, set it up in the hondata for PLX EGT but the gauge is reading a certain temp and the S300 is reading much less, is there a certain voltage offset i have to enter? Also included the file and pic
Re: PLX EGT not reading corrently
Switch the analog input to voltage, then check the voltage shown in SManager is the same as what PLX specifies in their manual http://www.plxdevices.com/v/vspfiles/su ... _guide.pdf (voltage = temp(C) x 0.00333)
jdelcorte
Post by jdelcorte »
Ok I am reading the current voltage for the EGT and also the Fluid temp. Now what do I do to get the correct temp reading?
What voltage do you see?
jdelcorte
Post by jdelcorte »
Breaking down the voltage and C to F it was reading the correct voltage, included pics
Ok, the next step would be to enter in a custom conversion.
For the EGT set the type to custom and the unit to temperature (F or C).
Conversion 0V = 0C and 5V = 1500C
For the ECT the conversion is 0V = 0V and 5V = 150C
jdelcorte
Post by jdelcorte »
I will try that in the morning.
jdelcorte
Post by jdelcorte »
Ok that seemed to work thank you, but after a few minutes the hondata switches it self From F to C by it self, very strange.. I can fix it back to F save it, upload it back to the ECU then a few
Minutes later they will start reading C again, not a big problem but just wanted to let ya'll know of the issue
