Fuel Pressure Input
SPOOLIN
Fuel Pressure Input
Post by SPOOLIN »
How would i wire up a Fuel Pressure sensor? Below is a link to a sensor I found and it says 12v power, 5v input, ground
I need to be able to log it and monitor it live if possible.
http://www.innovatemotorsports.com/xcar ... 265&page=1
www.MSSRACING.com
9.29 | 6.20 | 167
Re: Fuel Pressure Input
On what sort of s300? With analog inputs follow the help guide: http://www.hondata.com/help/smanager/an ... essure.htm
RofromNorCal
Post by RofromNorCal »
Hondata wrote:On what sort of s300? With analog inputs follow the help guide: http://www.hondata.com/help/smanager/an ... essure.htm
For me it will be Hondata S300 V3
jaygeezemail
Post by jaygeezemail »
Can the two grounds that are with the analog inputs be used for the sensor ground?
94 4dr. gsr 201,000 and growing miles running 10lbs from a cx racing turbo.
Hondata s300 v3 p28, cpr, rc440cc, pro series IM, 70mm tb, lc2 wb, half core rad. Cx turbo and other things
Yes, that is what they are for. Just don't wire in any high current device, like a relay or solenoid.
