ID1000 dead times @ 60psi fuel pressure
B18CR-X
Post by B18CR-X »
hi, can I have help to confirm if I have set the right dead times for my injectors before I go get it dyno tuned?
Injector dynamics ID1000 @ 60psi fuel pressure (key turned to ignition position and pump primes but engine off)
0.00 volt = 3.25
8.09 volt = 3.25
10.11 volt = 1.90
12.13 volt = 1.49
14.06 volt = 1.20
16.08 volt = 0.91
24.55 volt = 0.91
thanks in advance!
AREA876
Re: ID1000 dead times @ 60psi fuel pressure
Post by AREA876 »
Why 60psi and not 43.5psi ?
Because you need to use the dead times from the fuel pressure you actually run. 43.5psi / 3 bar is a common flow measuring pressure.
See http://www.hondata.com/forum/viewtopic. ... 000#p80180
B18CR-X
Post by B18CR-X »
thanks again hondata. sorry for asking it twice, just wanted to be sure..
