s300 with AVCR solenoid
Roberts
Post by Roberts »
Question. Is it safe to run Apexi AVRC along with Hondata s300 if both use one solenoid? I want to run boost by gear option with AVRC because it's always accessible and to use s300 boost cut in case of overboost. My concern is if I use one solenoid (which comes with AVCR) would it be ok to run wire from this solenoid to ecu for S300 Smanager boost cut?!
Thanks in advance!
Re: s300 with AVCR solenoid
You would be much better off just eliminating the AVCR and using the Hondata to fully control the boost. It has more options and will allow you to use all the safety features.
Roberts
Post by Roberts »
Thanks for reply! As i already said AVCR is in the car and accessible whenever i need it. Would it be safe to use same solenoid connected in one chain with s300?
You can try it and see since it sounds like this is what you want to do.
