full throttle shift
jeffyjeffracer11
full throttle shift
Post by jeffyjeffracer11 »
so I have a 93 Honda del sol with p75 ecu with added vtec components and boost control. I want to use one of the inputs with a switch added on the clutch pedal. I know one side of the switch will go to the chosen pin on the ecu, does the other side of the switch go to power or ground?
Re: full throttle shift
It depends on if the input you are using is a power or ground input. IF it is a ground input then it needs to go to ground.
