can't unlock from vin HELLLLPPPPP
dvmulisha
Post by dvmulisha »
My serial is fb us si 16813. I'm trying to sell mine and it says error authorizing vin...help!!!!
Re: can't unlock from vin HELLLLPPPPP
Make sure you have internet connection. If you do have internet connection, sometimes phone hotspots don't work and you need to use a different connection.
dvmulisha
Post by dvmulisha »
Iv used my Hotspot n my WiFi at home...sometimes I almost does it n others just goes straight to fail. Tried changing my address n updating n trying again
dvmulisha
Post by dvmulisha »
Does it have to be plugged in car to unlock it or could it be just plugged into laptop?
dvmulisha
Post by dvmulisha »
I mis typed serial, Fp-si-us 16183 sorry about that
First, are you returning the ECU to stock before you try to unlock?
Next, can you use the 'Check Internet Communication' function from the help menu.
Then connect the FlashPro to the vehicle and try to unlock. If you get an error message, please give us the exact error message.
dvmulisha
Post by dvmulisha »
I will try on my lunch in a bit. I did return it to stock but didn't check the connection.
dvmulisha
Post by dvmulisha »
Checked connection. Said "connection ok"
Error authorizing vin unlock - please contact support@hondata.com
I missed the history of this FlashPro. It should work now.
THREEXV
Post by THREEXV »
I am having this same issue can you please help. I have tried calling but no one picks up the phone. I have tried multiple internet spots and double checking everything to unlock this Flashpro. I have attatched my S# please help.
Use the Send Feedback function with the FlashPro plugged in.
THREEXV
Post by THREEXV »
I just sent the feedback on Hondata
Try now.
bobanickovski
Post by bobanickovski »
Hi. I have the same problem with my civic si...returned ecu to stock, deleted the history connection is still ok, but still getting the same message error authorizing vin est. Can u please help?! My flashpro serial is FP-SI-US-231832
What message do you get?
