ID 1000 values and fuel scalars
Posted: Mon May 18, 2015 1:33 am
Injector dynamics has values for all pressures for the dead times on their website.
For the 1000cc injectors they actually show 1015cc for 43.5 psi so I entered that value for my injector size.
I will be running 50 psi base fuel pressure without the vac line hooked up. I have a manifold referenced fuel pressure regulator btw. Once I set the base pressure I will hook up the vac line obviously. So I set the current pressure to 50, simple enough.
But my question is: Do I use the dead times that ID gives for 43.5 psi or the values that they list for 50 psi since that's what I'm running? I would think the values for 50 psi but since flashpro manager make be making calculations based on a test pressure of 43.5 and I entered 50 psi as current maybe it makes adjustments to the dead times as well?
Lastly, I checked the help contents and it didn't specify but under fuel> and overall trim. If I wanted to richen the entire fuel map 5% do I enter 5 or -5?
Because it says trim that makes me think a positive number will TRIM by that amount. Ya know kinda like when it says retard for timing, a positive value will pull(retard) timing....
I hope I don't regret this....Car is running well and has been but I know the ID injectors are top notch if not the best and I've seen the difference they make in my mustang so I want the same thing so we'll see
