06~11 R18A CIVCI wideband input to tune
newpassport
Post by newpassport »
Hi
My car is 06 R18A CIVIC,How to input wideband to tune the car and close loop.The manager do not have any setting funtion.Should i wring the sensor just like si?
Re: 06~11 R18A CIVCI wideband input to tune
You cannot use a aftermarket wideband to run in closed loop. The R18 does not allow for an aftermarket wideband input as there are no unused inputs available on the ECU.
newpassport
how to autotune
newpassport
Spunkster wrote:Have you read the information at: http://www.hondata.com/help/flashpro/au ... b=autotune
I can stock o2 sensor to autotune.
The stock sensor is a wideband and can be used.
CyberJumper37
Post by CyberJumper37 »
On the R18 you should be able to use the A23 ECU pin as a wideband input for the aftermarket analog output wire, but the Electronic Load Detector (ELD) must be disabled.
http://www.hondata.com/help/flashpro/in ... ectors.htm
From what I understand, the stock oxygen sensor tracks AFRs from about 12.0:1 to 19.0:1? And this range can be shifted to account for richer or leaner values, so an AFR min of 11.5 would have a max of about 18.5 if I'm correct.
So it seems the only use for an aftermarket wideband sensor would be for the gauge itself. If you really need a gauge (and don't want to disable ELD) perhaps you might just use it without the analog output wire.
Of course the next question is where do you place the aftermarket sensor. If it's inserted into the exhaust after the converter it will be less accurate but I guess it's better than nothing. Or you could use the Hondata app (w/ bluetooth) and put your phone on the dash, lol.
newpassport
CyberJumper37 wrote:On the R18 you should be able to use the A23 ECU pin as a wideband input for the aftermarket analog output wire, but the Electronic Load Detector (ELD) must be disabled.
The problem is no setting function in the fpmanager
