lambda datalog tables not working
muddauber351
Post by muddauber351 »
Hi attached datalog and map.
the lambda datalog tables are not working
as well as the percent to reach target lambda.
the boxes are highlighted when I drive but there are not any values in the box
Thanks John
Re: lambda datalog tables not working
What wideband are you using and what input on the ECU to you have it wired to?
muddauber351
innovate l-c1 wideband and input on d14o2.
everything has been working for the last year until last night. Thanks John
Check to make sure that all the settings are being met in Options, Settings, sensor overlay.
muddauber351
How should they be set to make it work.
I have tried many combinations
In sensor overlay one lambda
and if I use sensor overlay 2 what sensor should I be using I have tried af with no luck
Also when I change sensor overlay do I have to cycle the car on and off
Thanks John
Here are the settings used
muddauber351
That is correct I have it set like in your pic. Thanks John
