grounding the cyl head
aceman187443
Post by aceman187443 »
Where is G101 located (so I can ground properly) on the 02 civic si wiring harness??? Thanks a million!
Re: grounding the cyl head
I believe you are referring to the information listed at: http://www.hondata.com/techk20ground.html
aceman187443
Yeap that's it. I see that it connects at the cyl valve cover stud BUT where does the other end connect to (g101)?
You will need to look at the factory service manual or ETM for this.
www.helminc.com
