does the iacv work with alpha n tune? (100% TPS indexing for itb)
B18CR-X
Post by B18CR-X »
does the iacv still work with alpha n tune ? (cold start compensation)
b18c itb's , map sensor present and plumbed to each runner but using tps indexing only for fuel and ignition lookup.
Re: does the iacv work with alpha n tune? (100% TPS indexing for itb)
You will not be able to plumb an idle controller into ITBS to help them idle. You cannot rely on this for tuning ITBs.
