S300 red light
AlanSantisteban
S300 red light
Post by AlanSantisteban »
My car isnt starting the s300 has a red light on. What does this mean? If i leave the key in the on position the light will turn off, and the green light comes on, this happens on its own usually with a max of 5 min as of now.
Re: S300 red light
Sounds like a problem with the ECU. Some of the capacitors are probably going bad. You can try the s300 in a different ECU and see if the problem goes away.
AlanSantisteban
Re: S300 red light
Just wanted to get a second opinion before i went any further thank you i will get back to you and let you know how it went
