B16 JRSC Lean idle, bucking, surging
JDMEM1
Post by JDMEM1 »
Hi everyone,I have been searching for 2 weeks now trying to figure out the problem. I have a em1 with 60k on the clock I just put on a JRSC and have had nothing but issues since. I just bought the new Hondata S300 v3. When I start the car it will idle at 14.7:1 which is perfect. It will only do that for about 5 seconds and run lean too 18:1 or give me the --- on the AEM wide band. I'll add up to 20% more fuel and it does nothing. I'll take it for a spin and it will be at 14.7:1 at light loads accelerating but as soon as I cruise it goes lean again and starts to buck off the throttle and on. When I come to a stop the engine dies every time. Then when I go to re start it the thing starts idle surging so ill have to hold it at 5% throttle just to keep it alive while it surges. At WOT its at 11.7:1 where I like it but feels slow as crap. I am using the pre-set jrsc b16 map in the Hondata vault for a base map. Any one have any suggestions?
Thank you in advance!
Re: B16 JRSC Lean idle, bucking, surging
What injectors are you using? Has then been properly tuned?
