B16a fully Built, OBX turbo, RC1000cc, Ran good with chipped ECU, Installed s300 I cant get to run!!!!!!
cbye
Post by cbye »
Ive been tinkering with all the stuff on the software and cant get to run.......... i see tps section click read and says -5 min 60max... seems odd?? ive tried to adjust it, but not sure if its accurate, is special way update smanager from ecu LIVE!!!! so can watch tps open and close?? car ran ok b4 s300 install...... It was very doggy up to 3500, couldnt spin tires, but after 3500 rpm then was fine; so decided to get s300 make it right, just want it to run before bring to dyno. tears are falling i hope dont regret buying this thing!!!!
cbye
Re: B16a fully Built, OBX turbo, RC1000cc, Ran good with chipped ECU, Installed s300 I cant get to run!!!!!!
Post by cbye »
So nobody has a base map to make this thing run??? i can get to run if feather throttle.... i have fully ported Victor x intake, etc this thing is a beast, just need something to get to run!!!!!!!!!!!!!!!
cbye
Post by cbye »
Stock map sensor, i know could use 4 bar but dont think thats problem, tps is giving me red flag at -5 to 60, any help is appreciated!!!!!! im very rookie at this tuning with s300..... i know physics very well, im running two wideband o2 sensors, but those shouldnt effect running till warmed up and in closed loop....... WTF!!!!!!!!!!!!!!!!1 ahhhhhhhhhhhhhhhhhhhhhhh
cbye
Post by cbye »
Im about to tear this shit out and put back way it was!!!!!!!!!!!!!!!!!!!!!=(
heres the setup
b16a2 completely rebuilt, low comp pistons
Victor x inkate manifold(fully pported)
72mm throttle body port matched to intake
msd ignition system
walbro fuel pump
1000cc RC injectors
OBX turbo
Ram horn exhaust manifold
Front mount intercooler
what do i need to do to get to run?? a base map? am i forgetting to adjust something in smanager? PLEASE HELP!!!!
Have you contacted your tuner or dealer about getting help with a basemap?
cbye
Post by cbye »
I havent, so i call place bought it, they should have something for me to try?
AREA876
Post by AREA876 »
What brand wideband are you using? and what is the wideband reading when you start the vehicle
cbye
Post by cbye »
they are ac delco. One pre cat, one post cat. Im not sure how to see the readings if cant get running?? is there a live data screen so can see if all sensors working properly? sorry very new to this software, just need lil walk thru on how to see the data. Ive played around with bunch stuff. Like TPS i click read and its reading-5 and max is 60. Even when i adjust it, it still reads the same?? am I missing something?? is there an update button or can watch info live??
cbye
Post by cbye »
Dont have tuner, my friend has mustang dyno in his garage. Yeah he's loaded, lol, but they run drift cars and have no experience with hondata s300.
AREA876
Post by AREA876 »
I'm thinking that the AC Delco are the stock o2 sensor and not wideband. What controls them and where on the ECU are connected. If you press the display tab you should get a window showing a few sensors and you can add more to your liking.
AREA876
Post by AREA876 »
msd ignition system
walbro fuel pump
1000cc RC injectors
OBX turbo
Was the car running before with this setup?
cbye
Post by cbye »
Car was running with this setup before I installed the s300. But took old chips out for the s300 to be installed. thats why im soo baffled... i did get to run for few seconds but had to feather throttle to keep it going, just dont want hurt the motor being have so much invested into it. I tried to look up the Ac Delco o2 sensors and one is supposed to be wideband and one narrowband, but cant find part numbers on front one
cbye
Post by cbye »
on way to get bosch 4.2 wideband
AREA876
Post by AREA876 »
The wideband sensor needs a controller what brand controller do you have?
cbye
Post by cbye »
aem gauge controller, its the 4.9 bosch!!!! i still running stock map sensor, but been told its ez'er to tune with less range?? motor built for much more boost but baby steps right, lol
