Analog Temperature
jdelcorte
Analog Temperature
Post by jdelcorte »
Can you replace the stock AIT sensor with the Gm version now with the resistor? or they only work with the Analog input?
Re: Analog Temperature
What advantage would there be? The response time is about the same.
The temperature sensor input are for datalogging only. The GM sensor has a different resistance than the stock sensor. The Bosch sensors are much closer, but still a little different from stock.
