Intake temperature measurement with the MAP-Sensor?
R-12914
Post by R-12914 »
Hi,
is it possible to measure the intake temperature with the Honda OEM (stock) (1,7 bar (10 psi)) MAP sensor or other like rdx (2,8 bar (26 psi)) or the hondata (4,0 bar (40 psi)) MAP sensor?
I would need this to measure the charge air temperature after supercharger and intercooler!
If so, how it is possible to display the values in the Hondata FlashPro Manager?
If it is not possible, what should I do / install that it works?
Thanks!
2008 Honda Civic TypeR FN2
ECU: 37820-RSP-E02
Flashpro: FP-SI-INT-21153
Software: 3.6.1.0
Firmware: 185
Re: Intake temperature measurement with the MAP-Sensor?
This is not possible. It is only a pressure sensor.
