S300 Solid Red LED
7rrivera7
S300 Solid Red LED
Post by 7rrivera7 »
A customer brought me his S300v1 ECU and it's showing a solid red light and does not run his car properly. I connected using SManager and the settings are out of range and do not make sense. I can upload his calibration or create a new calibration but the red LED does not go out. I also tried erasing the ECU but SManager says it cannot erase it.
I tested his ECU with another S300 and it worked fine. I then put his S300 in my ECU and the same red LED came on.
I believe the S300 is bad and would like to send it in for repair. Please tell me how to proceed. Thank you.
Re: S300 Solid Red LED
Since this is out of warranty we cannot repair this. It will have to be replaced and the replacement will be a V3. The cost for this will be $400.
7rrivera7
Post by 7rrivera7 »
Ok, $400 includes shipping to Puerto Rico? Do I have to send in the bad S300?
Send an email to support <at> Hondata.com with the following and I will issue an RMA and give you further
instructions:
Name:
Address:
Phone:
Email:
Serial#:
Description of the problem:
