New feature since 2.2.7.0 -> Throttle Tip-in?
R-12914
Post by R-12914 »
Hondata,
whats the new feature in the Hondata Flashpro Version 2.2.7.0 under
"Throttle" -> "Throotle tip in fuel" ->
>Tip in fuel ECT compensation<
and
>Tip in fuel throttle compensation<
like this one (highlighted in red):
I can't find some info about this in the Flashpro Help!
Hondata, if you make amendments/extensions to the Flashpro Manager Software, then please expand/change also the help file!
This will help all users/tuners!
Without this, which is totally bad and incomplete!
Thanks!
2008 Honda Civic TypeR FN2
ECU: 37820-RSP-E02
Flashpro: FP-SI-INT-21153
Software: 3.6.1.0
Firmware: 185
Re: New feature since 2.2.7.0 -> Throttle Tip-in?
It is fairly straight forward. The ECU will add extra fuel when the throttle is opened quickly ('throttle tip in'). The two tables control how much extra fuel is added, by coolant temperature and starting throttle position.
We've updated the help file
http://www.hondata.com/help/flashpro/th ... meters.htm
typer86
Post by typer86 »
Very interesting...
What is the min and max values of this setting?
-100% and +100%
