tuning AFM fuel vs. AFM flow => low g/s
Posted: Tue Jul 21, 2015 1:22 am
by typer86
Hi, Hondata
I calibrate the RC750cc injectors and the idle dropping to low rpm is fixed.
Next step I checked the AFM vs S.TRIM and I found, that the low air flow meter g/s in the beginning must be increased from -8 until -5% to reach "zero" but I can not set lower values as 0,00 :-)
Thanks for help.
Re: tuning AFM fuel vs. AFM flow => low g/s
Posted: Tue Jul 21, 2015 10:11 am
What you need to do is tune the AFM flow table with stock injectors then tune the AFM fuel table with the 750cc injectors.
Posted: Tue Jul 21, 2015 1:20 pm
by typer86
Ok
Unfortunatelly the intake of the Supercharger kit does not support stock injectors. Only RC's are supported.
Any trouble with the engine in the future if not fixed?
Posted: Tue Jul 21, 2015 2:22 pm
It makes tuning more difficult. The easiest way to recalibrate the AFM for a different intake is with stock injectors. If you can;t do that, then you're trying to change two things at once (the AFM flow and AFM fuel tables).
Posted: Mon Jul 27, 2015 1:52 pm
by typer86
I could fix this with tuning AFM fuel tables.
Thanks for help again ;)
Posted: Fri Aug 07, 2015 1:05 am
by typer86
Hi Hondata,
Additional question about AFM fuel.
I would like to tune better the AFM fuel at the beginning but in the calibration only the following sections are available.
Unfortunately it is not possible to make an insert for new table or delete it.
How I can import the table 30.0 and 50.0? Can I drop the last tables to make that possible? (2500.0 and 2750.0)
Thanks for help
Posted: Fri Aug 07, 2015 12:08 pm
You change the values to insert a column. Starting at the highest column, enter the value from the next lowest column. Do this for both the air mass and injector duration.
Posted: Sat Aug 08, 2015 8:11 am
by typer86
Hondata, Thanks for help.
It works good with splitting the timinigs.
In the attached calibration and the first log it read lean (5-12!). Second log all close to zero.
At the moment I tuning only the AFM flow. I think the injectors are calibrated ok.
If I am drive 70 km/h STRIM is close to zero. If Iam driving near 100 km/h STRIM is 5-6% to lean with the same AFMflow values...
What can I do to bring both to zero? I have no idea. Make the AFM flow richer ...? I think no.
Thanks for tips!
Edit:
May the deadtimes are the problem?!
Edit2: Files removed
First log
Second log
Posted: Sun Aug 09, 2015 7:24 am
It is not possible to have the same airflow at 100 kph as at 70 kph. Therefore the airflow meter is not measuring true airflow correctly.
Posted: Sun Aug 09, 2015 11:41 am
by typer86
Thanks Hondata for your reply.
So I can drive this without any problems in the future? In your tuning guideline you write, driving to lean will damage the engine.
Finally for safe side did you recommend to tune this part (AFMflow) a little bit richer? (Approx. 1% or 2%?)
Thanks a lot for your support.
PS:
I learned a lot the last month and I am very happy to tune the car myself as I want.
Posted: Sun Aug 09, 2015 8:00 pm
Either switch to stock injectors in order to tune the AFM flow, or switch to speed-density tuning. Trying to tune both the AFM flow and the flow to injector duration at the same time doesn't work.
Posted: Mon Aug 10, 2015 12:47 am
by typer86
Hondata wrote:Either switch to stock injectors in order to tune the AFM flow, or switch to speed-density tuning. Trying to tune both the AFM flow and the flow to injector duration at the same time doesn't work.
ok I will try finally to adjust the AFM fuel to get a finally result.
