Hondata intake heatshield gasket
Math
Post by Math »
Hello,
is there any risk of using the hondata intake heatshield gasket during the winter? I live in Canada and it can go to as low as -40 celsius sometime...
Re: Hondata intake heatshield gasket
There should be no problem using it in the cold.
Aerodynamic
Post by Aerodynamic »
I bought a Hondata intake gasket that is un even meaning the cutout for the intake ports
are offset about 0.5 to 1mm.
Is there any heatshield gasket ou could by where the cutout for the intake ports are made to small so you can match port the intake gasket to the Engine head and intake manifold for a K20a2 Engine?
Br, Per
The gaskets we sell are the same size as OEM gaskets. We do not offer any other versions.
