using 90 mm throttle body creates rev hang
Garrett_si
Post by Garrett_si »
Hi, I use a 90mm throttle body on a 2.0L K20a (250whp SAE) on dynojet
the engine when upshifting in part throttle is doing rev hang.
Does you have an idea if something could be done to reduce it? since the throtle plate is big
thanks
Re: using 90 mm throttle body creates rev hang
If you block the idle valve, does the engine stall? If not, the throttle plate is leaky. If it does, then the idle valve is gummed up.
The throttle is mechanical. It can't be the ECU control.
