P2185 after wideband connection to pin A33
FlashPro questions & answers specific to the FD2 Japanese Civic Type R
jlhk
Post by jlhk »
Dear experts, I am new to Honda and Hondata, I have recently purchased a FD2 (Japanese Type R) and a Flashpro. To maximize my tuning accuracy, I have installed a wideband (AEM with meter and control unit) according to the instruction from flashpro help. I have tried all ECU pin and found that only the A33 pin (secondary ECT sensor) worked. The wideband is functioning well and I am getting a reading similar to stock primary O2 sensor, however, the CEL lights up and the code was P2185 (secondary ECT sensor high voltage), could someone help me with this issue? I could not turn off the error code by Flashpro. Thanks in advance.
Re: P2185 after wideband connection to pin A33
What calibration are you using?
jlhk
Post by jlhk »
Hondata r reflash
Can you post the calibration that you have uploaded to the ECU.
You cannot disable the secondary ECT sensor with that calibration type. I would switch to a race calibration for that vehicle.
jlhk
Post by jlhk »
May i know how do i flash a race type calibration into my ecu please?
jlhk
Post by jlhk »
My calibration attached.
I think I need a way to turn off the DTC code. I used other ecu softwares in the past and some are able to turn off the DTC code selectively, can my flashpro do that?
Thanks in advance.
jlhk
Post by jlhk »
Oic, thanks, i will try, sorry newbie learn slow
jlhk
Post by jlhk »
Dear Admins,
Converted to race calibration, problem solved, thank you very much.
Thanks for the feedback.
