Negative ignition values
xsenceo89x
Post by xsenceo89x »
Im trying to get negative ignition values as a launch rev limit. It worked a while back and now it doesnt. I have the launch rev limiter set at 6100. Vtec engage at 3mph so it will stay on the low cam until it starts moving. Previously, I could get the car to go to -10 but now it wont go lower than 0 when im stationary. Out of curiosity I discovered that I can get the high cam to go to -10. I dont know how long its been like this because I just hit the track friday night and looked at the datalog yesterday. I updated flashpro a couple times so I dont know when it changed.
Re: Negative ignition values
Post the calibration used as well as a datalog showing the issue.
xsenceo89x
Logs attached.
The Race calibrations have not been changed in many years and are no longer supported. All development is now done on the AFM calibrations that also have MAP based tuning capabilities. I would highly recommend that you use these type of calibrations instead.
xsenceo89x
Ha yeah that was it. I forgot I switched between the 2. Thanks man.
