S300 will not datalog correctly.
so_vayne
Post by so_vayne »
I have an s300 v3 and I can get it to datalog with the laptop but when it records based of parameters the sensors are all haywire. What could be the possible causes for this?
Re: S300 will not datalog correctly.
Download and install the latest software version (currently 2.4.4) and then re-upload to your ECU.
so_vayne
Post by so_vayne »
I did, and similar results.
Let me be more specific.
- Download and install the latest software version (currently 2.4.4)
- Re-upload to your ECU.
- Delete all datalogs on the s300
so_vayne
Post by so_vayne »
That is exactly what I did.
so_vayne
Post by so_vayne »
Same Issue still.
AREA876
Post by AREA876 »
Are you datalogging with PC and recording with ECU at the same time?
so_vayne
Post by so_vayne »
No, if I datalog with the ECM based on parameter set within the ecm is when I have the issue.
Has J12 been cut on the ECU?
so_vayne
Post by so_vayne »
Yes, this ECU and Hondata came from KS Tuned. I have verified it is installed correctly.
What is the serial number on the s300 board inside the ECU?
Can you post a picture of the ECU as well?
so_vayne
Post by so_vayne »
I'm currently away from home but I will be home Thursday evening and will post both then. Thank you.
so_vayne
Post by so_vayne »
Done, And done.
Has this s300 ever worked in this ECU?
so_vayne
Post by so_vayne »
It has datalogged correctly. It runs correctly. No issues.. Just will not datalog correctly.
