Fuel pump primes continously
Knox
Post by Knox »
Hi, I upload the calibration and ecu shows that I'm online and datalog sensor readings but map sensor read 4600 kps and fuel pump primes in every 2-3 seconds. Is there someone who have this problem before?
Note: map sensor is stock and it shows 4600kpa but sometime for just a second it shows 100kpa which is correct at half switch
Re: Fuel pump primes continously
What is the serial number on the s300 inside the ECU?
Knox
Post by Knox »
Serial number on the s300 is 32589 and the software that I'm using is the latest version 2.4.4.0. I tuned this car 1 month ago without a problem after that I starts to make this problem and car doesn't start.
I check the car with an other p28+s300 andits working great after that I check the s300(32589) with an other chipped p28 and works great again. So, I think problem is in the p28, do you advise some resistor or transistor to check if its ok or not?
Thanks.
Spunkster wrote:What is the serial number on the s300 inside the ECU?
The best thing to do would be to get a working ECU and use that. Trying to repair an ECU is usually more time intensive and costly than just buying a working one.
