Brand New Hondata 4 bar MAP Sensor Broken?
King Tut
Post by King Tut »
Car: 2006 Honda S2000
Hondata FlashPro Manager: Beta 2.2.9.0
I got a brand new Hondata 4 bar MAP sensor today, and I installed it in my 2006 Honda S2000 just fine. I then opened up my calibration and only went to the Sensors tab and changed the MAP sensor from OEM Honda to Hondata 4 bar. I then started my car, and it would barely run. I then swapped back to the OEM Honda MAP sensor and reflashed my previous calibration, and the car started and idled just fine. So it is either a bad Hondata MAP sensor or something wrong with FlashPro Manager. I saw a post where Hondata recommended posting logs of starting the car. I have attached logs of starting the car with the OEM Honda MAP sensor and the Hondata 4 bar MAP sensor along with the corresponding identical calibrations other than MAP sensor selection.
Any help would be appreciated. Thanks.
Re: Brand New Hondata 4 bar MAP Sensor Broken?
You will need to send the sensor back with a copy of the receipt and a description of the problem as well as your return shipping details.
King Tut
Post by King Tut »
Does that mean it is definitely the sensor and not FlashPro Manager?
If you have done what you said, then it sounds like the sensor.
King Tut
Post by King Tut »
Sent it back with all the items requested today.
