please help with idle problem
creedy
Post by creedy »
my car has started to not idle on start up, it will start and run at 2000rpm then drop slowly then just stall.
its on itb's and has been sat for 3 months doing nothing
AREA876
Re: please help with idle problem
Post by AREA876 »
Which version of S300 do you have (V1, V2, V3)
creedy
Post by creedy »
v3
AREA876
Post by AREA876 »
I would start by checking the map sensor because from the datalog I'm not see the map sensor reading change
creedy
Post by creedy »
Map sensor not connected it doesn't use it. I'm running itb's without a vacuum chamber
You must have the MAP sensor connected.
creedy
Post by creedy »
It hasn't had one connected for over a year and worked fine
I'm guessing it's how it was mapped (I know nothing about mapping)
You should probably take it back to the tuner to have them take a look.
