Page 1 of 2
S2000 KPro A/C issue with new KmanagerV4
Posted: Wed Aug 12, 2015 10:52 am
by Justinthecoastie
-S2000
-Serial no. 10529
-hardware version 3, software version 4.1.4.0
-AP1 basemap with added fuel for F22c
-After uploading map to vehicle and running vehicle until operating temperature, when I run the A/C the car shuts off at idle.Vehicle runs well without a/c on. This issue started just after I uploaded the newest manager.
Calibration:
newness toda adjust2.kal
Datalog:
ac issue.kdl
Re: S2000 KPro A/C issue with new KmanagerV4
Posted: Wed Aug 12, 2015 2:47 pm
by Justinthecoastie
I have discovered that if I move the idle valve adjuster to the highest setting, the car won't die when the A/C is on; however, when the A/C is off I now have too-much rev-hang. There are a couple of other things that did not translate well from the old version of k-manager to this current version. I hope adjustments for the s2000 users become available.
Posted: Wed Aug 12, 2015 4:17 pm
I'm trying to get one of our dealer to set this on his car.
As for rev hang, that is only present on car with drive by wire throttles.
There really should be no difference in the way the car runs from one version of K-manager to the other.
Try going to the online menu and erasing the ECU, close the program, reopen it and then upload the calibration again.
Posted: Thu Aug 13, 2015 12:37 am
by LK7R
This seems to be the same problem with all PRA ECUs. The data from datalog shows the same thing. Some IGN correction kicks in @ idle adding +20 advance which at idle is way too much. Alternator not charging, battery voltage goes down, engine stops. Havent found source of this IGN advance to set it lower. See theese posts: viewtopic.php?f=12&t=18384 , viewtopic.php?f=12&t=18801
Posted: Thu Aug 13, 2015 6:13 am
by Justinthecoastie
Spunkster wrote:I'm trying to get one of our dealer to set this on his car.
Thank you for responding. I guess when i say rev-hang, it is present because I have the idle valve at it highest setting and while at idle, if I tap the gas, instead of returning to idle like it use to it hangs at 1500rpm then down to 1200rpm and finally returning to what I have set. I am thinking the issue i with the way ignition control idle is set up. On my application, I am usable to use it and I'm working if kmanager is still using those values.
Posted: Sat Aug 15, 2015 4:14 pm
by Justinthecoastie
Any update?
Posted: Sun Aug 16, 2015 10:02 am
We're looking at it, and expect to fix the problem shortly.
Posted: Sun Aug 16, 2015 6:22 pm
by Justinthecoastie
Hondata wrote:We're looking at it, and expect to fix the problem shortly.
Awesome! Thank you!!!
Posted: Mon Aug 17, 2015 8:32 am
by Justinthecoastie
curtusz wrote:I don't seem to have an issue on my kprov4 pra K20a2 ep3, I find I get a slight rev drop on fans kicking in or a/c on and off... But nothing really different over factory... But revs fo hang sometimes around 1500 until I drive less than 3mph then it settles down to my set 1000rpm idle
Do you have the k-manager v4?
Posted: Mon Aug 17, 2015 3:32 pm
Fixed in V4.1.5
Posted: Mon Aug 17, 2015 5:49 pm
by Justinthecoastie
Hondata wrote:Fixed in V4.1.5
Thank you so much! When will we have access to V4.1.5?
Posted: Tue Aug 18, 2015 9:02 am
It was released yesterday
https://www.hondata.com/software
Posted: Tue Aug 18, 2015 12:28 pm
by Justinthecoastie
Hondata wrote:It was released yesterday
Great thank you so much. I didn't see a it in the threads, sorry.
Posted: Thu Aug 27, 2015 10:14 am
by The Spectacle
So for those of us that had the problem and corrected it, we should be able to return the idle slider back to where it started post software update?
Posted: Thu Aug 27, 2015 10:20 am
Yes it should work as it used to now.
