Use FlashPro Injector Dead Times in KPro?
KSeries4Life
Post by KSeries4Life »
Need a baseline tune on injectors with known flow and dead time numbers. I have a set of 06-11 Civic Si injectors. Can the flow and dead times be copied over to KPro from the numbers seen in FlashPro?
I would use these numbers as seen in FlashPro
Injector size: 310cc
6v = 3.166
8v = 1.952
10v = 1.360
12v = 1.022
16v = .622
Re: Use FlashPro Injector Dead Times in KPro?
You can try and see how those numbers work for you.
