suddanly wierd ignition values in the maps.
racepak
Post by racepak »
so i made a new map,
saved it
opened it and now the maps are retarded 4 deg than what i saved it,
what would cause this?
Re: suddanly wierd ignition values in the maps.
You will need to tell us what version of software you were using as well as post the calibration in question.
racepak
Post by racepak »
i found the problam,...
if you switch between low and high cam fuel or ignition while you "erase ecu" the maps skews.
Why are you using 'Erase ECU'? There is no need to do so.
racepak
Post by racepak »
why not? i tried to upload a new 2-3 times but the cel didnt turn off. after i erased it and upload the map again it uploaded,
had to upload a new map because of this ::)
http://www.hondata.com/forum/viewtopic.php?f=19&t=18900
AREA876
Post by AREA876 »
What version of SManager are you using
