Hondata & CPE for 2011 RDX
Hues10
Post by Hues10 »
Just installed the CPE air intake on my 2011 FWD RDX, went to reflash for the different intake, and noticed the calibrations for the K&N air intake are only listed under the 2007 to 2009 model years. There are only two maps for the 2010-11 RDX shown, one being the factory ecu, and one being the original Hondata map, which I had previously installed. Is the 2011 RDX ECU different than the 2007-2009 model EDU. I know 2012 is different, but really want to take as much advantage of the CPE intake as I can. Thanks
Re: Hondata & CPE for 2011 RDX
Yes the ECUs are different. You can use the reflash calibration and then to additional tuning to get the most out of your modifications.
