Hondata s300 v3 bluetooth module
ceekay101
Post by ceekay101 »
Hey guys,
Just wondering if someone could point me in the correct direction, having intermittent blue tooth connectivity issues with my hondata s300 v3. So i had a look at my board and it seems the bluetooth module isnt in the best condition, just wondering where i could find a replacement part (refer picture).
Cheers,
Chris.
Re: Hondata s300 v3 bluetooth module
There is nothing you can replace. That looks like powder. Can it be wiped off? Does it smell burned? What is the serial number on the s300?
ceekay101
Post by ceekay101 »
Spunkster wrote:There is nothing you can replace. That looks like powder. Can it be wiped off? Does it smell burned? What is the serial number on the s300?
I was able to wipe it off, just very odd that I'm having bluetooth issues and i find that on the bluetooth module. Very hard to smell, nothing distinct but it is quite small. The serial number is 30467.
That does not look like any damage, it looks like something was dropped on it. What device are you using Bluetooth with?
ceekay101
Post by ceekay101 »
Spunkster wrote:That does not look like any damage, it looks like something was dropped on it. What device are you using Bluetooth with?
Nothing was dropped onto it, was sealed till i opened it up for the first time since fitting it. I'm currently using an Samsung galaxy s6 edge, from memory have had issues with it for awhile? If its not replaceable as an individual part ill just have to put up with it :'(
Try using the Bluetooth with the lid off and see if it is any better. The lid will significantly reduce the range of the Bluetooth signal.
