Traction control datalogging question
Speedtek1408
Post by Speedtek1408 »
Ok so I'm finally using the traction control n got it working to a certain point. As I'm looking at my datalog. I see the slip rates and see the engine retarding and doing what it's suppose to be doing but it's not picking up the whee speed for the front and rear. With the tires off the ground I spin the tires and the module lights up with the tire I spin. So obviously all of that is working fine. It's just not recording my wheel speed. N I'd like it to work so I can adjust my launch compensation. Thanks in advance.
Re: Traction control datalogging question
Without seeing a datalog I'd guess that it could be a scaling issue. Do you mean the datalog downloaded from the TC and the s300? Can you post a datalog?
Also post your TC calibration file.
Do you have both USBs plugged in when you are datalogging this?
Speedtek1408
Yes both cables are plugged in. N I'll post my datalog when I download it from my car. Thanks.
What does it mean when u folks say it's a scaling issue?
