Hard start + misfire when hot.
AllRight
Post by AllRight »
Car: 94 honda civic ej2
Motor: B20B
ECU: P28 + S300
Hi. I connected CPR according to instructions. I checked it with troubleshooting manual and it is OK.
Sync light is not blinking when I try to start engine. It appears after 2-3 seconds and engine is starting. ECU disconected from sManager in this moment and it can't be connected while engine is working.
When engine is cold Idle is working good.
But there are misfires after warming up and when I press accelerator sharply pistons are knocking like ignition before top dead point.
It occurs before 3000rpm and after 4000rpm.
Can you help me? Thanks.
Re: Hard start + misfire when hot.
What spark plugs are you using?
AllRight
Post by AllRight »
Thanks!
AREA876
Post by AREA876 »
Was the spark plugs the problem?
AllRight
Post by AllRight »
Yes. NGKR5672A-8 does not have a resistor. I installed BKR8EIX and problem was solved.
