2011 TSX MT Flashpro Rev Hang
TSX6MT
Post by TSX6MT »
Does Flashpro for a TSX 11 MT control the overrun throttle compensation (OTC) and fuel cut delay (FCD)? I'm interested in eliminating rev hang but don't really want a tune. Basically, I'll like to know if I can buy a Flashpro, download the basemap and play with the overrun throttle compensation (OTC) and fuel cut delay (FCD) at will?
Thank you
Re: 2011 TSX MT Flashpro Rev Hang
I would recommend that you download the software and you can then see exactly how it all works.
TSX6MT
Post by TSX6MT »
Thank you! I didn't know you could download the software w/o purchasing the system firsts. I'll definitely will do that!
iselfdevi
Post by iselfdevi »
Reducing the overrun feul cut delay doesn't get rid of rev hang. It will just make the motor jerky when letting off the pedal. Is there going to be an option that will actually get rid of it??
Even with it set to 10 or 20, the rev hang was still there.
2012 Acura TSX 4cyl 6MT - flashpro - ct-e supercharger - ct-e icebox intake - deatschwerks 550cc injectors - RV6 exhaust/pcd - Vit tuned
We will add the throttle closing parameter to the next release.
iselfdevi
Post by iselfdevi »
Rev hang is now gone on my 12 tsx with the newest release. Is there a way to make it less "jerky" when letting off the throttle?
pepperdanky
Post by pepperdanky »
Set the overrun fuel cut delay back to stock and/or reduce the overrun MAP settingss.
iselfdevi
Post by iselfdevi »
I do have then at stock settings. I'll try your second suggestion. Should I maybe raise the stock settings past the stock 90ms?
ssjoeboe9
Post by ssjoeboe9 »
Can the "Overrun throttle opening" also be added to 2009/2010 TSX? Option is only available for 2011+ at the moment
Cu2suspect
Post by Cu2suspect »
I set mine to 40 for each gear and it shifts great for me, also tuned by vit
