Adjusting tps and now car wont run
boostedb18
Post by boostedb18 »
So i was adjusting the tps on my s300 v3 and the car starts right up but dies immediately, the car was driving just fine until i uploaded the new settings.
What could have happened? This is my daily and i need to figure this out immediately
Re: Adjusting tps and now car wont run
Close the program, reopen it, then load your calibration and upload it to the ECU again and that should correct it. You probably just had a partial upload.
boostedb18
Restarted the laptop and reuploaded the tune. Tps values are set to 0.63-97.23. The car starts right up but stall right away. Nothing other than the tps values were changed
What is the serial number on the s300? From Help, About, what is the version of software you are using?
Post your calibration and a datalog showing the problem.
boostedb18
I will post everything in the morning I'm not with the car now, thank you
Coupe1995
Post by Coupe1995 »
Any news on this? I'm having the same issue. As soon as I crank the car it dies immediately
Follow the posting guidelines and post your details.
