Dataloggin
Airmigs88
Dataloggin
Post by Airmigs88 »
I got an AEM wideband 30-4100 is it possible to hook it up to d10(eld) and to an analog input onto the s300 at the same time?
i currently have it connected to d10 but i would like to use to datalog air fuel ratio instead of reading voltage
Re: Dataloggin
You can read AF through d10 without hooking it up to anything else. Just make sure you have your units set correctly in Options, Settings, and in the Sensor list.
Airmigs88
Re: Dataloggin
Post by Airmigs88 »
thanks, i did notice that thers a slight difference between my guage and the s300 af readings but not by much, and i did use the thermostat to ground the aem guage im not really too woried about it though,
So now that im using the wideband as an input for my target lambda is it ok to completely remove the stock o2 sensor?
Re: Dataloggin
You can remove them if you want as long as you are not using the primary to run in closed loop.
