DTC P0341 dissable option
Josie
Post by Josie »
Hi Hondata,
It's possible to dissable the DTC P0341 code from the ECU like the K-pro? I can't see any option to do it.
We have some issues with a JUN Type 3 cams , double check the degree and all it's OK but the ECU fall into DTC code.
thanks
Re: DTC P0341 dissable option
The ECU is generating this code because the relationship between the intake and exhaust cams is incorrect. Disabling the code in the ECU will not fix the problem.
Josie
Post by Josie »
Yes Sir ,
but its not a cam timing problem , the aligment marks and cam degree it's ok , the problem is on the intake cam signal sprocket , it's not aligned with exhaust well and have no regulation option as you know.
We had that issue with another cams in a Kpro system and using the DTC error dissable option was great.
