DTC P0034 disable option
FlashPro questions & answers specific to the 2007-2012 Acura RDX
Kenb350z
Post by Kenb350z »
I was wondering if it were possible to disable this DTC for those of use running aftermarket turbos?
Re: DTC P0034 disable option
Is it possible to plug in the valve / actuator?
Kenb350z
Post by Kenb350z »
I currently do not have the valve / actuator. The sensor is still plug in; however, the valve/actuator is not connected. Do you think having a valve / actuator connected will help?
Yes. The error is low or high voltage, and with something plugged in it might go away.
Kenb350z
Post by Kenb350z »
Where would you recommend I run the hose's. The actuator sensor is plugged in, but there are no hose's running off of it. I think it is looking for boost or some kind of flow. The turbo boost sensor is fine, it is plugged into the BorgWarner.
