Multiple datalogging issues S300V2
Andrew
Post by Andrew »
Hi there, I have a few issues with datalogging on my S300V2.
1) data logging is no scaled properly, eg: a 13 second pass is logged over 26 seconds. Is there a way to change the scale?
2) logging does not start under the correct parameters, I set it to turn on based on engine parameters it doesn't abide by them and starts quite a few seconds later. It turns off under the correct parameters though.
3) I have been trying to wire in an Innovate LC1 to AN0, I took the car for a drive using the Smanager on a laptop to datalog. When I got back to check the log I found that the datalogging had flatlined at 4200rpm, it kept recording until the engine came down under 4200rpm. I have since found that particular data file has been corrupted and doesn't show the problem.
The car is a race only and was bought without any wiring, I have used a Rywire harness and have wired in my own +12v and ground wires but I have a feeling that my wiring might be causing interference issues?
Are there any diagrams out there showing EXACTLY what wires need to be 12v in and ground?
Attached are the calibration and one datalog file showing the first two problems
skullbasher
Re: Multiple datalogging issues S300V2
Post by skullbasher »
Having the same problem with my v3 but itll be random. Not guaranteed
What is the serial number that is on the s300 inside the ECU?
From Help, About, what is the version of software that you are using?
Andrew
Post by Andrew »
SN: 24120
Software is 2.5.0.0
Andrew
Post by Andrew »
Have just noticed that I am using BKR6E spark plugs, could this be part of the issue?
Does it datalog normally if you do not use the on-board datalogging and just datalog through the laptop instead?
Andrew
Post by Andrew »
Yes, if I plug the laptop in, start the car and hit the record button it records when I start and stop it.
It may have to do with your start and stop conditions, as you will still be below 2000 rpm and blow 20mph as soon as the datloog starts and it may be conflicting. Try setting your stop conditions lower than your start conditions.
Andrew
Post by Andrew »
Okay cool, I will try that next time I have the car on the track.
Any idea about the time scale issue?
Andrew
Post by Andrew »
Took a trip around the block in my racecar.
Changed datalogging settings and I get these three files.
Where is Doug?
Signed, a Disgruntled New Zealander.
Send an email to support<at> hondata.com with the following and I will issue an RMA and give you further
instructions:
Name:
Address:
Phone:
Email:
Serial#:
Description of problem.
include a link to this thread.
