KPro v1.3 & AEM wideband
mathblais
Post by mathblais »
Is there anyway I can use the AEM output as a output on the KPRO v1.3 ecu.
I was ready something about using the ELD pin... just can't seem to find out what does the ELD correspond to.
Thanks for your help
Math
Re: KPro v1.3 & AEM wideband
I'm not sure what you mean by K-Pro v1.3.
If you mean using the ELD input to see ELD reading you can do this but you cannot run closed loop from it.
http://www.hondata.com/help/kmanager/ecuconnectors.htm
mathblais
Post by mathblais »
the kpro board (pcb) is revision 1.3
There is no v1.3. It will either be a version 1, 2, 3 or 4.
What is the serial number on the K-Pro board inside the ECU?
mathblais
Post by mathblais »
then it's 1
I presume they sometime can be different revision..
