S300 hardware problem
fhcampos
Post by fhcampos »
- serial number of the s300 inside the ECU
Serial > 12,396 S300 v1
- version of software being used (Help, About)
2.5.0.0
- the calibration (as an attachment)
- a datalog of a problem (as an attachment)
can´t datalog
- what sort of vehicle you have
Honda Civic Coupe d16z6 - turbo
- what sort of ECU you are using
p28 manual
- anything about the car which has been modified from stock which may affect the ECU (don't include what sort of rims you have nor stereo etc).
Nothing
- a specific description of the problem
S300 v1, never had a single problem with it for 4 years. Today, after 20 days without even look at the car, didn´t work at all.
- CEL Always on
- Poor idle and revs, can´t run.
- Can´t comunicate with ecu properly - cant see real time parameters, cant see or erase DTC´s
- It uploads(or at least shows on the software)
- Erase ECU doesn´t work.
- D1 led always red.
- D2 led sometimes is green, but mostly off.
- D4 green
What I have tested so far:
- Another ECU - same problem
- Change the 20m cristal of the s300 - same problem
I usted to work for a dealer here in Brazil, I have good soldering skills and knowlege of eletronics, if you could help me fix this would be great, 330usd to ship the s300 to you would be a great cost right now(4:1 currency ratio today in Brazil) - it is my personal project car.
Contact email - fhcampos@gmail.com
Re: S300 hardware problem
Thank you for the detailed information. Given it was working and then stopped working when the car was left for a period of time, I would guess it is the non volatile RAM on the S300. There's no remote repair that we can do - the S300 would have to be sent in to upgrade.
fhcampos
Post by fhcampos »
Thks for the reply!
I think you are right about the ram, going to try some tricks.
If Im not able to repair it, do I need a RMA number or just send the ecu with the form filled?
Thks again for the help.
You will need to obtain an RMA number before sending it in.
fhcampos
Post by fhcampos »
Yeah, I couldn´t repair it =((
Need a RMA number, will send you the S300 + ecu + form.
Send and email to support <at> Hondata.com with the following and I will issue an RMA and give you further
instructions:
Name:
Address:
Phone:
Email:
Serial#:
Include a link to this thread.
fhcampos
Post by fhcampos »
E-mail sent. Please reply =)
fhcampos
Post by fhcampos »
Still no answer =(
Can I send the ECU? Using a S300 upgrade form maybe?
