Injector Driver Box
AREA876
Injector Driver Box
Post by AREA876 »
Love to know more
Re: Injector Driver Box
We'll post up some information soon.
SPOOLIN
Post by SPOOLIN »
ping
www.MSSRACING.com
9.29 | 6.20 | 167
SPOOLIN
Post by SPOOLIN »
Yes, I've read all that. Just waiting for more information on a release date and cost.
www.MSSRACING.com
9.29 | 6.20 | 167
The release is probably going to be late Feb. Retail price is to be determined.
SPOOLIN
Post by SPOOLIN »
can we at least know if this box will power and fire off the injectors in order by itself with the aid of some kind of signal or a wiring diagram. Im trying to plan ahead a little so im not blind sided with something as im planning for this unit.
www.MSSRACING.com
9.29 | 6.20 | 167
It depends if you have 4 or 8 injectors, and if they are slaved or staged.
SPOOLIN
Post by SPOOLIN »
i have 2000 on top and 1000 on bottom, was planning on staging...
was originally going to strait wire slave the bottoms until i saw this device was coming out...race only car obviously..
www.MSSRACING.com
9.29 | 6.20 | 167
SPOOLIN
Post by SPOOLIN »
So the driver will have four individual injector inputs which have to be split off of the primaries and then four individual outputs for the secondaries?
www.MSSRACING.com
9.29 | 6.20 | 167
Yes, the diagram may not be clear on that (but it is not the final version). For sequential operation it needs 4 inputs and 4 outputs. For staged operation it needs an enable input from the ECU.
AREA876
Post by AREA876 »
Which would be better sequential or staged, what's the difference?
You want both.
Sequential injection is where each injector fires at the right time for each cylinder, so that as much as fuel as possible goes in the cylinder when the intake valve is open. You need the four input and outputs for sequential injection.
Staged injection is where one set of injectors are 'staged' to operate at a certain rpm/load etc. That way you can use smaller injectors for idle/low load, and then both small and larger injectors under high load / boost etc. If you wanted to use two fuel systems you could also run different fuels (92 octane and E85 for instance), but it's simpler just to use E85 for both injectors. The only advantage would be fuel consumption.
SPOOLIN
Post by SPOOLIN »
I use 2000cc injectors as the primary and im going to use 1000's as the staged set to come in around 38-40 psi of boost. I'm assuming this is fine. Alot of your literature and posts suggests using the small ones with the big ones on stage.
Ive been running upwards of 48 psi at "100%" duty cycle on a set of just 4 2000's for around a year or so haha.
www.MSSRACING.com
9.29 | 6.20 | 167
