k20a3 with 05-06 a2 trans EP3
chronmellow37
Post by chronmellow37 »
So I recently picked up a kpro v4 prb. Would like to know if a base map is accessable for k20a3 motor running an 05 06 type S tranny. Tranny is not plug n play due to differences in vss. So I am currently not running vss. I was informed that krpo can still function properly without vss. How can I get a base map started with the combo of my motor and trans. And is there a straight forward solution to getting the speed sensor to work? I am using stock a3 wire harness, full exhaust, 05 06 type S trans. Help???
Re: k20a3 with 05-06 a2 trans EP3
The A3 harness will not work without changing plugs and modifying the wiring. You will then need to use the VSS input on the K-Pro to convert the high frequency signal. This will not operate your cluster, it is only internal to the ECU.
