Sorry it is a dumb question...
samsul
Post by samsul »
The stock o2 sensor is pin in d14...can i change the pin into d10(eld input) to get 0-5v...is it usefull to do it for reading the afr 0-5v...
AREA876
Re: Sorry it is a dumb question...
Post by AREA876 »
This should only be done if you are using a wideband
samsul
Post by samsul »
Acctually when i remove the r136&r138...what will happen to d10 pinout....is it will be 5v output source...
AREA876
Post by AREA876 »
Are you using a wideband
D10 is an input and it detects 0-5v. It is not an output or a source for getting 5v.
